TIMINATOR
- Jan 26, 2020
I looked at the lifter PDF, and, in one instance it says more preload makes less top end HP, later it says less lash (mechanical) and more pre load makes the cam seem bigger. The second starement is correct.
With a mechanical cam, opening the lash definatly makes the cam effectively smaller, just as hydraulic lifter bleed down does. This results in less lift and effective duration, as the lash must be "taken up" before lift starts,(remember to multiply the extra lash by the rocker ratio before you subtract it from advertised lift).
More lash means less effective duration, and its easy to visualize. Advertised duration is measured at .006" tappet rise, duration at .050" is just that, it is duration at .050" tappet rise. I.E. A 280 duration Comp hydraulic cam is 280 degrees at .006 tappet lift, and "duration at .050", IS the duration at .050" lift, and it is 230 degrees. Thats a loss of FIFTY DEGREES DURATION, for .044" difference of lift!
Now, back to what I have been saying:
Standard hydraulic lifters have about .190" travel. At a "half turn down" its about .160" travel. Bleed down occurs from both open and closed spring pressures, and inertial pressure from the weight of the entire valve train: lifter- plunger, pushrod, both ends of the rocker arm, valve, retainer, locks, the upper, moving half of the spring, umbrella type stem seal, and any oil that is inside the pushrod, and any oil all over the valvetrain externally. Inertial loads quadruple with doubling of the RPM also. Bleed down is much worse on blower, nitrous, and turbo engines due to their higher cylinder pressures at exhaust valve opening. Thats one of the reasons why larger, higher RPM hydraulic turbo cams have longer exhaust duration than intake.
Conical and beehive springs reduce the weight of the movable end of the spring, retainer, and locks, and are more efficient if they have enough pressure to control the valvetrain.
Back "in the day" when cam lobe design was out pacing the then current valvespring technology, Rev Kits were popular on roller applications. They were nothing more than springs that set up against the bottom of the head, and pushed against the roller lifter, helping it to better follow the cam lobe and allowing the valvespring to only need to control the upper end of the valvetrain.
Buick V-6s and all of the LS engines have small diameter springs, and are both limited by spring installed height and diameter and can both benefit from these "Rev Kits."
JMHO
TIMINATOR
JMHO
TIMINATOR
