SignUp Now!Originally posted by The Pro
You are out of your mind. My cam makes great continous power all the way to my rev limiter (currently set at 6000 RPM).
I could run *more* RPM if I had the appropriate valvetrain...
I run solid lifters, 4000 stall, and it's a DAMN good street car.. (I drive it all the time)
Go try it yourself instead of regurgitating someone elses less then accurate information...
Originally posted by qwknuf6 jr
How about some ET's for the ppl with larger cams ?Lets see if the loss of steetablity is worth it???![]()
there is no loss of streetability. [/B]
Originally posted by Blown&Injected
Is 224/224 a big cam? Because if it is there is no loss of streetability.
I have the 224/224 - you guys think it is OK for what I have done to my engine?
I'll say that the car is totally streetable and has no low end problems. However, since my MAF's have died on my the last two time I have been to the track and a turbo got munched by parts from on of the MAF's, I cannot say if it helped my at the track - also went to MSD 50's so it really is not a fair cam only experiment.
Mark, if you read my posts to this thread carefully you will find that I already asked others about the size of my cam and mentioned that I do not have a true way of comparing ET's with the 224/224:
I will say again, with the same converter and turbo that I went 11.7x @116.xx (on blue tops, with only 22# of boost, 100 octane, street tires, did not lock the converter, bad 2-3 flair in the trans) I cannot detect any loss of low end and there are no streetability issues at all.
MY ET??? - I hope to get my ET down to low 11's and to cross the 120 mark - full weight/full accessory car with closed exhaust, street tires, and street legal 100 octane.
Q. What prompted the change to my engine? A. I wiped the cam that was in the car so I needed another one. The car is buzzing thru the traps so it did not seem as if a bigger cam would hurt, The O2's were dropping to the high 600's with the blue tops so in with the 50's - that's all there was to those choices.
I do not have a bar in the car, and I am not planning on putting one in so I was just attempting to make the best of the current situation. So, does anybody think I hurt things with the 224/224 as far as power/ET goes? The power and ET thing is all I'm really concerned with because I know there are no driveability issues. As far as the low end, the car goes to full boost and breaks the tires loose about as fast as I can slam the throttle down - but since the last two MAF's died on me on the first pass on my last two trips to the track I have no real idea how I'm doing.
