BLACK MAGIC RACING
formerly turbo_canuck
- Jul 18, 2001
Working on my stage 2 over the winter, It's a 274 off-center, 4" bore, 9to 1 comp., crower crank, carillo rods, je pistons, stage 2 "031" heads, 90mm tb and elbow, conv. 4 barrel, Fast sequential, modified oil pickup, pt-88, stock ignition, th-400 w/brake, 4000 stall, and have a few questions.
1. Is the comp #93-850-9 296-R4 cam a good choice for my application? (294 in,300 exh adv. dur, 264-268@.050, 650 650 lift, 104*ls)
2. Can i use the lifters from the old cam, a weber 218-212 solid roller?
3. Will the oiling system i have be sufficient for mid 9's?
4. Is the fel-pro #1000 the right head gasket for me?
Thanks for any help you can give! :biggrin:
