Was having some intermittent driveability issues...seemed the car would buck or miss after I gave it a good run. The code that eventually flashed was the cam sensor. I changed that...and the IAC as well :biggrin: after I cracked that off trying to pull of the plug.
I set the cam sensor as mentioned on gnttype..it was dead easy. The car fired right up with a LOT of valvetrain noise...so much I shut it off and called people for advice but it went away when it got good liquid to the valvecovers. I let the car idle for a while then just took it out for a shakedown run. It worked fine for the first 10km as I took it easy...then on the way back I started getting a little hard on it. I didn't have the scan tool hooked up and never got over 15psi...but it started to miss/buck after a quick dig by Tims. Then I let it run a bit more down a couple straightaways...and the light came on. I'm pretty sure it was the same code as it was doing the exact same buck/miss/died at the end of my road.
Could this be caused by something else? I've got a MAFTpro that I've wired in...IMO loose wiring issues shouldn't come and go with load...am I correct? I was wondering if maybe the timing chain was slack enough to cause an error b/t it and the crankshaft sensor? Is there a tensioner on this chain?
Any suggestions? I'm getting near my wits end.
Ford Family pricing is in effect for 2 more weeks and I'm thinking of ditching my two 8yr projects for a new diesel 4x4 because I'm sick of walking home.
