ChrisCairns
Senior Member
- May 24, 2001
So I just fired up my new engine. No oil pressure. First thought was I'd lost the prime. I had originally primed it on the stand but I had to drain the oil and turn the engine over to remove the pan to check on something. I attempted to remove the cam sensor to reprime it and found the cam sensor had popped out because some stupid person hadn't put in the hold down bolt and washer.
It's now fixed and running nicely.
However, out of curiosity, how would the engine start, probably 4 times, without a cam sensor?? I'm thinking that the cam would still be turning the sensor but the odds of having it in the correct position are pretty slim after it popped out.
My question......Does FAST really need a cam sensor to start the car??
Thanks, Chris
Thanks, Chris
