Ran into a problem with the cam sensor settings after replacing the timing chain. Car won't start and its struggling to turn over, like its 15:1 compression. I believe that I screwed up when I installed the cam sensor back after oil priming. Here's my two questions :
1) With the DS valve cover off, on the #1 cylinder would both intake and exhaust valves be closed at TDC ? Not sure what stroke I am on when installing sensor.
2) Using the casper's tool, is it possble at 25 ATDC that I could turn the sensor wrong direction and get a lit LED ? Essentially out of phase.
Any suggestions would be appreciated..
thanks, Scott
thanks, Scott
