O
OldGrayII
Guest
O.K., I'm about to pull my hair out with this dam Cam Sensor! After buttoning everything up from the timing Chain and Blueprinted cover Install I did as the Instructions said - With the motor at TDC, matched Zero mark on balancer, I Installed the Cam Sensor, Then moved the motor to the 25Degree mark (1.50in) on balancer, Loosened the sensor, plugged-In the caspers tool, and spun the sensor clockwise about 1/2" and the Light came on, kept spinning about another 3/4 to 1 inch and the light went out, turned it BACK counterclockwise till the ligt JUST came on, and tightened the bolt!! Now, the weird part is this:
A. The sensor cap wires are facing forward(6 oclock)??
B. The Timing Chain Instal instructions on GNTTYPE say to move the motor to the 0 mark (TDC) on the balancer and install the sensor, everything else I've read says to Install it at the 25Degree mark ATDC (1.50in) mark...Which is correct??
C. Caspers tool says to loosen sensor, turn it 1/4 turn, stop and turn it counterclockwise until light JUST comes on, and bolt it down. Well I loosen sensor, turn it 1/4 turn clockwise and BING the light comes on!! So I continue turning it (clockwise) until the light goes out, then I go counterclockwise until it just comes back on, and bolt it down. Why is the light coming on at the WRONG TIME????
