NorCalTurbos
Slowing down to SPEED UP!!!
- Nov 9, 2013
I'm going to attempt to set my cps I have a few ?s do I need to pull it while I set the crank to TDC on compression stroke and then pop the cps back in. As of now the car run ok but the volt reading on the cps is 7v I turned it and the voltage didn't drop
Also the car would fire up I turned it back to where I started and it ran??? All help welcome
