Feb 11, 2019 #1 B bob brady 3 black cars Joined Sep 19, 2015 Messages 110 need the shaft, as i broke the screw in mine while attempting to upgrade the cup.
Feb 11, 2019 #2 R reggie44 Active Member Joined Oct 15, 2007 Messages 530 Bob, sorry I don't know the e-bay # but there is a NOS one on e-bay right now and I believe it is one of the Members from here. Good luck.
Feb 13, 2019 #3 turbo nasty Turbo Dojo / MNTR Joined Jul 19, 2001 Messages 9,478 bob brady said: need the shaft, as i broke the screw in mine while attempting to upgrade the cup. Click to expand... A machine shop can get the remainder of the screw out. Heat the shaft up to temp to defeat the loctite on the screw before removing it.
Feb 13, 2019 #4 turbo nasty Turbo Dojo / MNTR Joined Jul 19, 2001 Messages 9,478 bob brady said: need the shaft, as i broke the screw in mine while attempting to upgrade the cup. Click to expand... Another option, I rebuild these and can rebuild it for you as well. Including the broken screw removal. Thanks
Feb 13, 2019 #5 B bob brady 3 black cars Joined Sep 19, 2015 Messages 110 i broke a small drill bit inside the screw
Feb 13, 2019 #6 F Fat Nat Well-Known Member Joined May 25, 2001 Messages 1,411 I have a few shafts I believe. I’ll check when I get to the shop
Feb 13, 2019 #7 F Fat Nat Well-Known Member Joined May 25, 2001 Messages 1,411 Fat Nat said: I have a few shafts I believe. I’ll check when I get to the shop Click to expand... Or I have a complete cam sensor with cap for 100.00
