9
91cam447
Guest
Hi Everyone, I am new to the board but have been reading and getting alot of insight from you guys for quite awhile. I have a question that I can't seem to get answered. I don't have a GN but maybe someone on here can help me. I have a BBChevy that I am trying to get the F.A.S.T. unit setup and going. I understand how to get the crank trigger setup. Ok, here is where I am having problems. I have to run a front drive distributor due to lack of manifold clearence. This requires me to use a MSD cam sync sensor w/ the magnet installed on the Jesel cam pulley. Now, the manual says to verify that the cam trigger occurs 10* sooner than the crank trigger but not more than 45* sooner. Now, when I installed the cam trigger I set the #1 cyl. at 70* BTDC and drilled my pilot hole for the sensor in the bracket and touched the cam pulley so I would know where to put the magnet. How do I go about verifying that it is triggering within the "window?" Or, is the "window" so big that you really don't have to check it? Am I missing something? One more question and I will stop rambling on. What in the software settings has to be changed in order to get the individual cyl. controls to work? I have the SEFI unit w/ NOS controls and the individual cyl. controls. The software is the windows version. I hope someone here can answer these questions. You guys have a great site here as you have helped me understand a great deal about the F.A.S.T unit. Thank you.
Brad
Brad
