Cam spring and button
racer5252
I just put my front engine cover on but am concerned maybe the cam button and spring came off or is cockeyed since I had to twist and muscle it around a bit . Is there a trick to check this without pulling the cover back off?
you might be able to see with a small telescoping mirror inside the cam sensor hole. Or through the fuel pump blockoff plate with a larger mirror (that's a visual straight shot to the button area)
Thanks earl, I never even thought about the blockoff plate. I will try that in the morning
It keeps the cam pushed back against the block until the engine speeds up enough for the oil pump to take over.
It's just a spring that pushes the cam away from the timing cover. The 'new style' has a flat roller bearing on the end to cut down on friction and the entire assembly spins with the camshaft.
thanks buddy, im going to search more on this. i know i have seen them on a few sites just cant picture where she goes, your description helps
