May 6, 2014 #1 8 84beastregal Member Joined Mar 2, 2012 Messages 218 Is a edelbrock can good for mild setup Sent from my C5155 using Tapatalk
May 7, 2014 #2 E earlbrown runs with scissors Joined May 26, 2001 Messages 7,539 If you don't have to change the cam, I wouldn't mess with it. Since you say you've a 'mild setup' odds are you're better off sticking with an established good cam.
May 7, 2014 #3 8 84beastregal Member Joined Mar 2, 2012 Messages 218 Its a stock 231 carb but do in a blow through on it will it be a upgrade over the stock Sent from my C5155 using Tapatalk
May 7, 2014 #4 E earlbrown runs with scissors Joined May 26, 2001 Messages 7,539 Not if the new cam goes flat it won't be an upgrade. The reward just isn't worth the risk.
