can anyone id this converter
bar87
a whirlwind of doom
had the inspection cover off, and i noticed the converter had h-6 stamped around it.... it footbrake stalls at about 2500, and doesn't lock up, but that could be because my speedo isnt working...anyone?:confused:
there should be a little sticker on the front by the hub too.no factory issue 2004r convertors stall at more than 2100 with stock engine so its probably a modified mcss convertor .they are usuallt stamped 6 indicatind a hi stall turbine and 14 blade stator.
if so, then its a lockup converter? if thats the case ill get my speedo workin...;)
it should be unless they ommited the clutch(in the aftermarket) when they built it, per customer order
