83TurboGuy
Whynd it up
- May 11, 2010
i got an 83 t-type and i was woundering if i would be able to install a intercooler and if so would there be a diffrence
if not why not???
SignUp Now!i got an 83 t-type and i was woundering if i would be able to install a intercooler and if so would there be a diffrenceif not why not???
An intercooler is inserted between the turbo and the intake. Kinda hard to do on a draw through system since you have fuel going through the turbo. If it was an injected engine then it wouldn't be an issue but on a draw through system it's not feasible. You could do a pre turbo cooler but you have an issue with freezing the carb up from the low temps. Click on the second link in my sig and you can see where Aj (dr_frankenstein) and I discuss this.:smile:
He is real.:biggrin: Glad to see you on Rich.:smile:
are you running the alky injection on your regal charlie?? I have some parts here to set it up, but wasnt planning on setting up the alky till the motors running right.
yup I have.
have all the designs for air to air and water to air to use intercooler on the draw thru.
however, it requres a change to one of my systems. will not accept anything factory.
A.j.
I like Nitrous Oxide as my chemical intercooler. It's simple, does not take away or add to the distance the fuel must travel and it's very effective and hard to beat it's cooling properties. The only way I see a drawthru system being intercooled effectively and still be a true drawthru is to run natural gas as your fuel, it will never puddle inside the intercooler matrix...
didnt GM do a srt of weird intercooler set up between a roots blower and the intake manifold for their V series cadillacs? or whatever the cadillac version of the corvette was with the edges.....
this is correct.
the key is special intercooler design and setup. has to look a cetain way inside. and hint hint.... the intercooler is based on ROOTS blower technology
this is my sweetheart that Charlie has helped me with for almost 2 years now, much back and forth and at the cost of several V6s
but what you need to know, can all be taught by the VW guys.
A.j.
SHUSH!
dammit. letting all the secrets out.
A.j.
