Oct 4, 2010 #1 G GUNMETAL T-TYPE New Member Joined Sep 24, 2010 Messages 25 I found these in the trunk of my car id like to know what they are.
Oct 4, 2010 #2 R RegalT-type85 New Member Joined Jan 23, 2010 Messages 934 GUNMETAL T-TYPE said: I found these in the trunk of my car id like to know what they are. Click to expand... That looks like the lower ( maybe upper but going with lower) half to the stock air box. The lower item is flywheel/TC cover.
Oct 4, 2010 #3 P phillyturbosix Moderator Staff member Joined Aug 24, 2003 Messages 4,285 Yup lower stock air box and torque converter cover/inspection plate.
Oct 4, 2010 #4 G GUNMETAL T-TYPE New Member Joined Sep 24, 2010 Messages 25 Thanks for the info does the insp cover need to be put back on or can it stay off?
Oct 4, 2010 #5 chopped39 Well-Known Member Joined Aug 30, 2004 Messages 4,271 GUNMETAL T-TYPE said: Thanks for the info does the insp cover need to be put back on or can it stay off? Click to expand... I would put it on. Suck up a bag into bellhousing and see it get forced into pump seal I have seen bags wrapped into pinion seals lots of times.
Oct 4, 2010 #6 G GUNMETAL T-TYPE New Member Joined Sep 24, 2010 Messages 25 chopped39 said: I would put it on. Suck up a bag into bellhousing and see it get forced into pump seal I have seen bags wrapped into pinion seals lots of times. Click to expand... ok ill put it back since im doing the rear main seal and oil pan tomorrow thanks for the info
