When I have PL monitoring on the graph screen it is showing my Voltage Input to IN4 & IN5 as a flatline...Do I have something turned off??? Not sure what the readings are for specifically...Any help would be appreciated.
4 and 5 are additional analog inputs that can be fed by a variety of devices. on the F3 screen you can use the pull down for each and it will show what can be used to feed the inputs.
