Can someone explain
mzunino
When I have PL monitoring on the graph screen it is showing my Voltage Input to IN4 & IN5 as a flatline...Do I have something turned off??? Not sure what the readings are for specifically...Any help would be appreciated.
4 and 5 are additional analog inputs that can be fed by a variety of devices. on the F3 screen you can use the pull down for each and it will show what can be used to feed the inputs.
BTW, right clicking in any of the graphs will pull up a list of other things you can display in that graph.
