Fuel Pump recommendations
Danster
Senior Member
I need to replace my fuel pump and it's been a long while since I have purchased one. I saw Full Throttle is selling a Deatschwerks DW550 46mm In-Tank Pump (Check-Valve Equipped).
Not really looking at racing much these days but still would like to have a good one installed.
Thoughts?
Dannyo
Are you on stock fuel lines? If so, that pump would over-run the stock return line.
The bigger pumps are too much for the stock return line. Causes fuel pressure to be too high at low idle.
Pretty much need to stay under 300Lph if you have stock return line.
Good to know guys, I am still on stock fuel lines.
So which one is better for my application? Again, not sure I will be doing much racing anymore. I do have a AlkyControl installed. Probably need to update the pump but other than that it's pretty much stock, with a TA-49.
^this
With all new wiring from Racetronix including inside the tank wiring. And a 10 or 12ga ground all the way to the battery or alternator case.
Deatschwerks DW550
Thanks for your post, didn't know this existed, Hellcat 525 and 535 has some competition, though the DW810L is still the pump king.
