Thank you.CTX-SLPR said:Honestly in my opinion the best looking F-body since the 69 Trans-Am
SignUp Now!Thank you.CTX-SLPR said:Honestly in my opinion the best looking F-body since the 69 Trans-Am
Camaro is lookin good Jim!Metal said:I'm almost done with a TTA drive train into a 92 Z28, we've swapped the rear end, springs, suspension and 1LE brakes.
Basically it will be a TTA in Camaro Trim.
http://krif.com/jims92z28
Thanks Eric, Andy and Mike talked me into it at Woodward saying how 'Easy' your swap was.91Bird305 said:Camaro is lookin good Jim!
galoush said:80s Caddy coupe deville 2 door , i think the guy was from Brooklyn
TurboTrix said:Hi All,I just Completed my 87 S10 Blazer,87 GN 3.8 Turbo motor,200r trans with B@m Shifter,Stock s10 rear end with Spiders Welded up(temp untill i get new rear end) Stock GN Intercooler,Stock Turbo and injectors, currently running 12psi Just typical mods so far FPR,TPS new heads with LS1 Springs/retainers costum 3" doen pipe and exhaust Truck Went 12.51 at 16Psi Pics Coming up soon
TurboTrix said:Ok I gathered some pics, Notice the steering column had to be slightly moved towards passanger side in order to clear drivers side header.Truck is NOT complete as far as interior/exterior goes mechanically runs excellent.Also notice Costum Engine Oil Cooler.
it would make the truck faster. :biggrin:Turbo1dr said:Those pictures makes me want to put my Malibu's engine in my Syclone.
TurboTrix said:I noticed they make those digital guages for my truck as well,are they direct replacement?Did you have a problem fiting them on your Malibu?
