The intercooler bracket spans between the lower (pivot) bolt for the alternator (stud bolt about 6" long with a 15mm head, and a 8mmx1.25 threaded stud sticking out of it) and the lowest timing cover stud. The stud has a 5/15-18 thread (block end) and a 8mmx1.25 stud. (13mm nut)
The small bracket goes on the lower AC compressor bolt. The bolt slides through the slotted end, through the aluminum bracket then through the AC compressor with a nut on the front side of the compressor. The open end of the bracket goes to the lower forward exhaust header stud, and uses a 13mm (wrench size) flange nut.
Figured I would be real specific seeing how you are new to the game, and things get a bit tight in the front of these cars.:smile:
