protracracing
- Oct 1, 2001
I just bought a car with an SMC kit and need to no if i can use methanol .
thanks
Dennis
thanks
Dennis
SignUp Now!You are very much correct (as usual), my point was that my particular pump that came with my SMC kit, has a sheath around the body that melts when it comes in contact with certain solvents....which would prove what you said about the SMC pumps to be true. Alky is friendly with just about every plastic Ive ever seen.Razor said:Not all plastics are created equally. Perfect example is a one gallon milk jug and a red gasoline container. gasoline will eat through the plastic jug, not the plastic red jug..
The plastic tanks have no issues with methanol. The Uplon is only used when a pump that needs lubrication is used.
And the pump has to be compatible with methanol. The pump inside the old SMC kits was not and never was intended to be used with methanol alcohol. Its intention was denatured alcohol with an added lubricant. Dont believe me, call Steve at SMC for clarification.
Once the pump takes a ****.. replace it. Is what it is.
turbo2nr said:I ran 100% Meth with no lube for years. No problems. After about two years, I felt it was on borrowed time. I used around twenty gallons (four drums) of meth.
System got pulled out of my car.
