SignUp Now!i have mine set as the high for 5500
i have mine set as the high for 5500 and the low @ 600.
I had an uncle in a hysteresis band. He played the ukelele.It's called a hysteresis band
i read the help section and it didn't give me any relative info on the high and low rpm settings.
Actuallly that is an interesting way to stay in open loop through first gear, then go to closed-loop in 2nd gear.Good idea Bob! If you have the correct firmware in the Classic box you can have it turn the O2 off when you ground a wire (ESC, I think). I used to use this to shut my O2 off when I was on the 2-step but still be able to have complete closed loop operation when not on the 2-step.
