I installed Razors kit, new H.D. actuator, Erics alky chip and some other bolt on's (rjc powerplate, 30 lb injectors, K&N)
Here is the problem
Before the Alky kit and with the original actuator rod and other bolt on's (rjc powerplate, 30 lb injectors, K&N) the most boost I could get was 18 with the actuator rod at its shortest.
I have the new H.D. actuator at a point that when you take the clip off, there is no tension on the actuator rod and can be slipped off or on.
Under WOT my boost on the boost gauge is 22 and sometimes hits 25 with .07 KR with the alky dial set at 6
I thought that the H.D. actuator starts at 18 psi when its at a length that when put on the pin would just slip on and shorting it would raise the boost.
Any ideas why I have so much boost or how to reduce it ?
Here is the problem
