I've noticed when driving that heat is blowing in from under the dash near the console. My blower is not on but the heat is coming through. I figured that the heat control valve went bad and was stuck open allowing hot coolant to go through the heater core but I changed the valve yesterday and no luck. So, think it has something to do with vacuum?
Does the heater control valve open or close when vacuum is applied? Hopefully it opens with vacuum because if that is the case I will just take the line off. The car doesn't go out in winter and I never need the heat. This was real annoying last year but I figured it was the valve until I ruled that out yesterday. I guess I could bypass the heater core if need be but I'd rather not.
Any thoughts would be greatly appreciated.
