can't turn car off key won't turn back.
bpman1234
Yes I had to pull the ecm wire at the battery to cut the car off and then disconnect the battery .
Is it time to change my ignition switch?
Ok thanks would that be available in any auto parts or will I have to order it .thanks
or you may need to adjust the lockout rod under the car
try twisting the column by the dash counterclockwise
Did all that and it it in other gears reverse neutral Park ignition key wouldn't even move at all Even put a little WD-40 there But nothing worked got the ignition from Advance auto parts 18 bucks
This is a new one on me,never heard of this happening before. Sorry cant help, maybe linkage problem.
