Car bogs
87 national
Fresh rebuilt motor I have a translator pro and scan master when I give the car gas it bogs it is idling at 900 1000 rpm. Fuel pressure is 40 when you give it gas it gose up to 45 what can I adjust no maf because translator all I know I have the idle control and fuel reg what do I adjust them to or is there anything else. The motor is all stock turbo parts
car warm
post all the scanmaster numbers
at idle in park
in drive brake applied
With the key on engine of get the following numbers of the tpro sensor monotor page.
MT=
MP=
UT=
VE=
there was no question mark after I posted "car warm"
those were instructions
car warm
and post ALL numbers....click through the scanmaster starting with your 02's of course
sorry i though you asked if the car was warm
these numbers where taken right after the stat opened for the first time
02 97 but bounced up and down highest i saw was like 200 at a idle
af 03
lb 32
int 150
bl 128
cle 168
ats 71
tps .46
iac 00 was 53 cold
cc 158
pl 1.3
sp 26.9
car was idling about 1000 1100
af 03
lb 32
int 150
bl 128
cle 168
ats 71
tps .46
iac 00 was 53 cold
cc 158
pl 1.3
sp 26.9
The bl is indicating you are lean.
Add like +10 to the mainscale in the tpro.
good catch. Acutally it's the INT. but who's counting ;) ;)
Hopefully it's just a lean condition that can be tuned out, and NOT a vacuum leak
IAC and TPS will also have to be brought into better specs. Preferably IAC around 25 +/- 5-10, and TPS around .42-.44 after all is said and done.
How do I adjust the int and iac in to specs I have first gen translator pro
hopefully your scanmaster is on top of the dashboard, if so then proceed to the next step.
Screw on drivers side of the throttlebody is for IAC, screw in decrease in number, screw out increase in number
Start with just the nub or 1 thread after you get it to where there might be just one thread showing, flip your scanmaster over to TPS setting and point it out to your windshield so you can read it while your under the hood.
loosen up your two TPS sensor bolts (pass side of throttle body)
Gently pull your tps out towards front of car, now watch your SM numbers, gently tap it down, up, back er whatever untill you get to .42... now tighten without moving it.
Start car, let IAC numbers settle.... if too low or too high... repeat untill you get it right.
post back
