Tim Barnum
- Oct 15, 2001
Will a bad O2 sensor cause the car to cut out under WOT? The car runs good on the street but when I get to the track it cuts out all the way down the track. The only thing I do at the track is remove the cutout. The fuel pressure is turned down to 38 lbs with no vaccum. The EGT reads 1500 deg at the top of the run. I've been running 114 oct on the street and at the track. I know the O2 is bad now because I got a code 13 and 32 on the Scan Master. I did manage a 12.51 @ 108 with a 1.69 60 foot even with it surging back and fourth. What do you do about a code 32? Let me know your thoughts if you would. Thanks Tim
