Confirmed no power to fuel pump. I am using Racetronix Hotwire set up. No signal from the original factory wiring to fuel pump that now is being used to energize the Hotwire relay. Confirmed power into the ECM. not sure which pin is for the fuel pump.. I know there is a momentary signal to pressurize the fuel system when the ignition is initially turned on .Which relay in the engine bay is the fuel pump relay? Which pin sends the signal from the ECM? Anything else that I'm missing that may interrupt the fuel pump?
