Ok heres the deal. 1987 grand national 89,000 miles just bought it off a guy. There was just water in it. No antifreeze. Car froze up. Now there is a lot of water in the oil. Water and oil is leaking out on the floor from the rear main seal.
Block cracked? Heads cracked? Water pump cracked? All of the above? Should I just take it all apart and head to the machine shop? :frown: Car does still run and the compression is good. No water runing out anywhere I can see. Just into the engine as far as I know. Any ideas on what to do?
