This is a weird problem and hard to describe. It seems like spark is getting blown out.
Under load (normally 10psi or more) the car just falls on its face. It makes no power and goes nowhere. Boost gauge reads 20psi at WOT, scanmaster shows 780-830 o2's, 0 knock (every one and awhile 1 or 2 degrees).
I changed the coil pack, wires and checked the gap on the plugs (AC CR42TS - .035) - nothing worked.
I'm going to try a smaller gap, somewhere in between .028 and .030 (just to see if it truly is blowing spark out).
The coil pack I bought wasn't a Delco. I bought a GP/Sorensen coil pack as it was $60 cheaper than the Delco. From everything I've ever seen/heard aftermarket coil packs work just as well as the Delco's, which is why I bought it. Is this ture, or should I have bought the Delco?
Could this be a bad ignition module?
