TwoLaneBlackTop
About done
- May 25, 2001
Well, a few days ago I drove my car a little bit and parked it outside, I spilt a lot of gas around the car a few minutes before and figured I will let it rain on the car to wash the smell away. Any ways I have regretted letting the car stay out in the rain.
I went to pull it in the garage and I turned the key to ready and no fuel pump prime, I tried to start and it acts like it want to turns over goes then stays at 800 rpm for a second then dies.
Any ways I push the car into the garage and later that night check the DFi box connection I figured maybe they are loose, well when I unplug the connector a little bit of water came out of the conector, some how water got to my DFi box conector err, there was no sign of water any where else but a little got to the point where the stock harness connects to the DFi harness. I dried it out, hooked things back up and turn the key to the ready and sure enough the pump primed, I figured it would start right up next time. I also took the top off the DFi box and nothing seemed to be burnt up. (This is a GEN 6 SEQ. unit)
Well, today I put my brand new coil pack/module on my car and turn the key to the ready and pump primes, then I try to start and the same thing happens, it just wont run!
I am getting fuel, I have correct pressure, and the plugs were wet. I am also getting a spark, pulled a plug and grounded it and saw spark. My cam sensor is set the correct way and the car ran fine a few days ago. I can turn the key to the ready and I can access the Di with my laptop.
I am afraid that maybe the unit got damaged by the tiny bit of water that got to the connector, but if it was why would I have any spark or fuel? What do you guys think? Did I damage my DFi? And what else could this be?
