- May 25, 2001
Posting in this forum because I have a Fast XFI system. Not sure gremlins are Fast related?/
Problem is car runs and drives great off the track, but at times on the drag strip the car will "nose over" badly at 1/2 track. Car does not die, data logging is lost, check engine light comes on. Try full throttle again, car stalls
badly.
At our Ford/Buick shoot out this weekend on the final pass they said it popped real loud when it nosed over.
We thought it was fixed Saturday AM when we ran a ground wire from the battery top terminal to the intake. Thinking was the top post was having and internal problem. My top post powers the Fast system.
Made a pass after adding this ground, car ran great. Final pass in elimination its back to it loosing power.
I am adding some data logs, they are brief and weird. The logs on all of the sensors look like "saw teeth"
These saw teeth logs showed up on some logs weeks ago when I was dealing with a dying/ dead 3 BAR map
The volts show 15+ is this an issue to the Fast?
Added note Friday night while in the staging lanes, starting and stopping the car at one point I tried to start the car and just cranked, Fast said ECU could not be found. Panicked, tried to start again, all was fine ?
Looking for ideas.
Big thanks to E Ticket for his help at the race.
badly.
Looking for ideas.
