BLACK6PACK
1 sec reaction King
- May 24, 2001
Ok, I posted this a couple of weeks ago. I installed Max Effort, Direct Scan and SMC EGT. I started it up and took it down the block and it had no power. It would just cut out and stumble at anything more than 1/8 throttle. I got it back home and stuck in a regular chip - no change. I then unhooked Direct scan from the ECM and reset the computer. It worked fine after that. So I put the Max Effort back in, still ran fine. So I figured that the pins on the ECM weren't clean enough, so I spent another 2 hours cleaning the pins off. I hooked it back up and started the car and it idled fine and I was getting normal readings across the board on the laptop. I didn't have time to take it for a test drive so I shut her down and didn't mess with her.
Friday night I go to take her for a cruise. I fire up the laptop and everything seems to be fine. I get to the stoplight about 1/4 mile from the house and she starts searching for an idle speed. I pull away from the light and she runs fine. About 1/4 mile from the light it felt like she went into limp home mode. I had to drive a couple of miles before I could get turned around an go back home. Again anything more than 1/8 throttle and she would chug and spit. Took about 4 minutes to get up to 35 mph. It isn't throwing any codes and everything on DS and Scanmaster are in spec. Whats going on?!?!
