1984 t-type
Murphy's Law
- Jul 11, 2010
Ok from a cold start with the MAF sensor hooked up it will fire right up go to a high idle and die, if it warmed it it will start go to a high idle come down and run rough and sputter also the idle will surge up and down. Now if I unplug the MAF before I start it it will start right up go to a high idle come down a bit but still idle kinda high, but will run much smother and won't cut off. Of course I figured the MAF was bad so I changed it out with a refurbished sensor and no change. Any ideas
