white 86 t
- Sep 28, 2015
just got the car running it idles fine but put it in gear it sputters and has no power any ideas?
Need more info . Give us the back story and how you got it running.just got the car running it idles fine but put it in gear it sputters and has no power any ideas?
no exaust leacks at all it has a stock replacement cam also has 3200 stall converterOk. Worth a try. So in your first post you say it won't brakestand. Any header leaks? If this cam is bigger than stock it might not like a stock torque convertor. Bigger cams like looser convertors.
How does it drive?
when you changed that cam sensor, the whole thing or just the cap?
Take the cap off and try to turn to reluctor ring with your fingers, it should not move. There is a tiny tab that can break off. I'd unscrew it and see if the tab is gone.I just changed the cap
i checked it and its tight doesnt spinok cool.
