D
Datsunboy
Guest
Okay guys, i bought new plugs that will be going in my motor sometime this week along with a fuel filter.
I pulled a plug today just to take a look and they looked pretty clean... almost TOO clean. I think the car may be running lean. Would this cause me not to be able to make more than 10lbs of boost? It also tries to die off idle sometimes. Then sometimes it runs great with a slightly ruff idle. It has decided that it wont do more than 10lbs of boost come hell or high water though.
I think the 02 is okay, but can someone give me an idea of what the Mv reading should be at idle from it so i can meter it?
The car started doing the wierd boost thing before i put the marvel mystery oil in btw, and i am on a fresh tank of gas right now.
I also bought a fuel pressure gauge so i can see if im running out of pressure under boost!
Thanks guys -Evan
Thanks guys -Evan
