BlackBeauty
- Dec 15, 2001
Hey folks, well since I started the car after work tonight, I had been having problems. When I started the car, it fired up, then died, and jumped back to life idling around 1200rpms. Then the rpm's would go up and down. Oh well. So I start driving home, and the motor stops running all of a sudden, then a second or two later will come back on. I limped it home, as it did this a number of times... halfway home the SES light came on, and I got a code 34 from my ScanMaster, which means the ECM was getting low numbers from the MAF sensor. As I pulled into the driveway, the car turned off completely, I had to turn the key to fire it up. Then I popped the hood, tapped on the MAF while the car idled, couldn't notice any difference since the car was stumbling the whole time. Then I reset the ECM (to get rid of the code) and unplugged the MAF, car ran better but still threw another code 34. With these symptoms, what do you think I should check next? Is it a bad MAF? I have never messed with my MAF sensor, but it appears to have only one screen. Do the original MAF's have one screen at each end? I only have one screen on the filter side, no screen going to the turbo. Thanks for the help.
If you have a spare MAF around and live nearby, feel free to e-mail me! I'll try to check my e-mail, as this phone line is being cancelled tomorrow (changing to Roadrunner this weekend hopefully).
