Car throwing 12 & 13 codes at me!
FreeJack
Got something strange. I have turbo link 4 up and running and I'm getting a strange reading on the malfunction codes. Under normal driving conditions, I'm getting a 12,13,12 malfunction codes in that order. It does it every time.
Has anyone seen this before?
:rolleyes:
It should always have code 12. That tells you the ecm can diagnose itself. 13 is oxygen sensor. Replace it.
The only Bosch i ever ran only lasted one run with race gas. AC's are the way to go. Does it show the sensor is active. Should be changing alot at idle.
