b4black
- May 24, 2001
I picked up a 84/85 Hot Air downpipe this weekend. It's very similar to the 78/83 downpipe. It has the same 4-bolt flange like the 81/83 pipes. The lower 3/4's is the same as the 78/83. It's just the top 1/4 that's different. The 84/85 has tighter bends and a 2-bolt flange.
I think is you could get a 84/85 2½" DP cheap, you coild lop of the top and have a new section added fairly easily. Or try to convince someone that makes a Hot Air downpipes to make a Carb/Turbo DP. They sould be able to with a stock pipe for a pattern.
So who makes a cheap, good quality 84/85 2½" DP?
