For Personal Use Only Print This Page • Print All Pages
Loading...
Rebuilt/Reconstructed Title
A Rebuilt/Reconstructed vehicle is a salvage vehicle that has been repaired and restored to operation. These vehicles are often severely damaged before they are rebuilt and refurbished parts are typically used during reconstruction. In most states, an inspection of the vehicle is required before the vehicle is allowed to return to the road. Manufacturer Buyback or Lemon
A DMV or a state agency marks an official document or issues a Manufacturer Buyback/Lemon title when a vehicle has been repurchased by the manufacturer. Not all states issue manufacturer buyback titles and the specific requirements for a lemon law vehicle varies by state. Odometer Rollback
If a more recent odometer reading is less than an older reading, then the odometer may have been tampered with and "rolled back". Manufacturer Recall
Automobile manufacturers issue recall notices to inform owners of car defects that have come to the manufacturer's attention. Recalls also suggest improvements that can be made to improve the safety of a particular vehicle. Most manufacturer recalls can be repaired at no cost to you. Basic Warranty
Most manufacturers offer a basic warranty for new vehicles. These warranties vary by manufacturer and typically last for a certain amount of time and/or a set number of miles. Not Actual Mileage Title
When the seller certifies, under the Federal Odometer Act, that the odometer reading does not reflect the vehicle's actual mileage. This may occur because the odometer was tampered with, broken, or replaced. Junk Title
A Junk Title is issued on a vehicle damaged to the extent that the cost of repairing the vehicle exceeds ~ 75% of its pre-damage value. This damage threshold may vary by state. The majority of states use this title to indicate that a vehicle is not road worthy and cannot be titled again. Some states treat Junk titles the same as Salvage. Loss Due To Fire Title
The vehicle sustained major damage due to fire. In most states, fire damage titles are issued when the cost of repairing the vehicle for safe operation exceeds its fair market value. Exceeds Mechanical Limits
A vehicle with a 5-digit odometer cannot accurately track mileage after 99,999 miles because the odometer rolls over. This title is the result of a seller certifying under the Federal Odometer Act, that the odometer reading EXCEEDS MECHANICAL LIMITS of the odometer. Structural / Frame Damage
In most cases, a vehicle is inspected for structural or frame damage, depending on the body design, after an accident or other incident. All levels of accidents from minor to severe can cause structural / frame damage and in most cases it can be repaired. Airbag Deployment
Occurs when the driver, passenger or side airbag has been used or deployed during a crash or other incident. If an airbag has been deployed, it must be replaced by a qualified technician. Have this car inspected by a mechanic prior to purchase. Salvage Title
A Salvage Title is issued on a vehicle damaged to the extent that the cost of repairing the vehicle exceeds ~ 75% of its pre-damage value. This damage threshold may vary by state. Some states treat Junk titles the same as Salvage but the majority use this title to indicate that a vehicle is not road worthy and cannot be titled again in that state. The following eleven States also use Salvage titles to identify stolen vehicles - AZ, FL, GA, IL, MD, MN, NJ, NM, NY, OK and OR. Total Loss
An insurance or fleet company declares a vehicle a total loss when a claim exceeds ~ 75% of its pre-damage value or if the vehicle is stolen and not recovered. This damage threshold varies by company. These companies typically take possession and obtain the title. Not all total loss vehicles result in a DMV-reported branded title, like a Salvage or Junk title. See the glossary for more information. Accident Indicator
Various events could indicate an accident in a vehicle's history, such as: salvage auction, fire damage, police-reported accident, crash test vehicle, damage disclosure, collision repair facility and automotive recycler records. See the glossary for more information. Hail Damage Title
The vehicle sustained major damage due to hail. In most states, hail damage titles are issued when the cost of repairing the vehicle for safe operation exceeds its fair market value. Flood Damage Title
States issue flood titles when a vehicle has been in a flood or has received extensive water damage. Standard Equipment
Power Steering, Air Conditioning, AM / FM, Power Brakes, Tilt Wheel, 6-digit Odometer Safety Options
4 wheel ABS, Running Lights, Dual air bags front/active (manual) belts with passenger side deactivation switch
1999 CHEVROLET K1500 SILVERADO
1GCEK19TXXE223579
3 DOOR EXTENDED CAB PICKUP
5.3L V8 MPI OHV / 4 WHEEL DRIVE
Standard Equipment | Safety Options
Hi-I'm the CARFAX Xpert™. I'm here to help you better understand the data in this CARFAX Report. Did you know...
We checked over 5 billion records from thousands of data sources for this vehicle
This vehicle qualifies for the CARFAX Buyback Guarantee
The last reported odometer reading was 89,107
A CARFAX Vehicle History Report is based only on information supplied to CARFAX. Other information about this vehicle, including problems, may not have been reported to CARFAX. Use this report as one important tool, along with a vehicle inspection and test drive, to make a better decision about your next used car.
The number of owners is estimated by CARFAX
Year purchased 1999 2005
Type of owner Lease ---
Estimated length of ownership 6 yrs. 3 mo. 2 yrs. 10 mo.
Owned in the following states/provinces Minnesota North Dakota
Estimated miles driven per year 25,550/yr ---
Last reported odometer reading 110,000 89,107
CARFAX guarantees the information in this section
Salvage | Junk | Rebuilt Guaranteed
No Problem Guaranteed
No Problem
Fire/Flood | Hail Damage | Buyback/Lemon
Guaranteed
No Problem
Not Actual Mileage | Exceeds Mechanical Limits Guaranteed
No Problem
GUARANTEED - None of these major title problems were reported by a state Department of Motor Vehicles (DMV). If you find that any of these title problems were reported by a DMV and not included in this report, CARFAX will buy this vehicle back.
Register | View Terms
Not all accidents or other issues are reported to CARFAX
Total Loss Check
No total loss reported to CARFAX. No Issues Reported
No Issues Reported
Structural / Frame Damage Check
No structural / frame damage reported to CARFAX. No Issues Reported
No Issues Reported
Airbag Deployment Check
No airbag deployment reported to CARFAX. No Issues Reported
No Issues Reported
Odometer Rollback Check
Inconsistent odometer reading indicated. No Issues Indicated
Inconsistent Odometer Reading
Accident Check
No accidents reported to CARFAX. No Issues Reported
No Issues Reported
Manufacturer Recall Check
Check with an authorized Chevrolet dealer for any open recalls. No Recalls Reported
No Recalls Reported
Basic Warranty Check
Original warranty estimated to have expired. View Info
Interested in an extended warranty? Warranty Expired
Warranty Expired
Tell us what you know about this vehicle
Still looking? Find similar cars just listed for sale in your area.
Let us do the work! Get daily updates of CHEVROLET SILVERADO vehicles for sale in your area.
Email:
Zip:
1999 CHEVROLET K2500 SILVERADO
Price: $7,995.00
Mileage: 99,781
Color: Grey
Body Style: 3 Door Extended Cab Pickup
Engine Type: 6.0L V8 MPI
Standard Equipment: Power Steering, Air Conditioning, AM / FM, Power Brakes, Tilt Wheel, 6-digit Odometer
Free CARFAX Report Reliable Auto Repairs & Sales
914-736-7517
Distance: 48.37 mi
View Dealer Inventory
Contact Dealer
2000 CHEVROLET K1500 SILVERADO
Body Style: Pickup
Engine Type: 5.3L V8 MPI OHV
Standard Equipment: Power Steering, AM / FM, Power Brakes, Tilt Wheel, 6-digit Odometer
Free CARFAX Report Fullerton Ford Jeep Chrysler Dodge
908-722-2500
Distance: 37.54 mi
Contact Dealer
Body Style: Club Cab Pickup
Engine Type: 4.8L V8 MPI
Free CARFAX Report Prestige Toyota
Distance: 34.43 mi
Contact Dealer
A CARFAX Vehicle History Report is based only on information supplied to CARFAX. CARFAX checked over 5 billion vehicle history events and found 11 record(s) for this 1999 CHEVROLET K1500 SILVERADO (1GCEK19TXXE223579).
Purchased: 1999
Type: Lease
Where: Minnesota
Est. miles/year: 25,550/yr
Est. length owned: 7/6/99 - 10/20/05
(6 yrs. 3 mo.)
Date: Mileage: Source: Comments:
07/06/1999 Minnesota
Motor Vehicle Dept.
Cockeysville, MD Registered as lease vehicle
Don't be confused by the two locations in this record. The title was held in Cockeysville, Maryland but the car was registered to be driven in Minnesota.
08/17/1999 150 Minnesota
Motor Vehicle Dept.
Cockeysville, MD
Title #K2290L644 Title or registration issued
First owner reported
Loan or lien reported
07/24/2002 76,762 Service Facility Vehicle serviced
Oil and filter changed chassis lubricated
08/29/2002 Minnesota
Motor Vehicle Dept.
Chaska, MN
Title #J2410P595 Title issued or updated
12/10/2002 86,944 Service Facility Vehicle serviced
01/17/2003 89,000 Service Facility Vehicle serviced
Miscellaneous service performed
Suspension system serviced
05/02/2003 96,743 Service Facility Vehicle serviced
06/12/2003 99,913 Service Facility Vehicle serviced
10/10/2003 110,000 Service Facility Vehicle serviced
Purchased: 2005
Where: North Dakota
Est. miles/year: ---
Est. length owned: 10/20/05 - present
(2 yrs. 10 mo.)
10/20/2005 89,107 North Dakota
Motor Vehicle Dept.
Fargo, ND
Title #5494019 Title or registration issued
New owner reported
INCONSISTENT ODOMETER READING
Hmmm...hard to tell whether this reading represents an odometer rollback or a clerical error. Confirm the mileage with your dealer or qualified mechanic.
10/15/2007 North Dakota
Motor Vehicle Dept.
Fargo, ND
Have Questions? Please visit our Help Center at
CARFAX used car VIN number search, auto history check, vehicle history reports
