I am sitting here with samples from Car Motorsports and Jax, as well as a sample cut from my original carpet from under the console. I thought I'd post an unbiased comparison of the two products to help someone in the future doing a search trying to decide on which one to get (as I was a few weeks ago).
First the color match. The Jax carpet is a closer match than either the 1033 (Dark Blue) or 1019 (Lt. Blue) I received from Car. From a few feet away the Jax product is bang on, being just a hair darker. But then the carpet, even from under the console, is old and perhaps a bit faded. Both Car products are too dark. The Light blue is closer. But...the richness of the color with the Car products is much, much nicer than the Jax carpet. I'll post a follow up later today after I have a chance to lay the Car products in the car and see how it blends with the rest of my blue interior. I'm sure it's going to look off a bit, but I also think it's going to look in fact better than an original color match for all but the purist's restoration. I'll call the color a draw.
Next the texture and overall quality of the material. This is where the Car products stand out far and above the Jax. The pile on the Car products is close to twice as deep as Jax's. Pushing a finger into the carpet reveals the Car product to be more plush. The Jax carpet is glued to a rubberized plastic backing while the Car product uses a fabric backing making it much more flexible than Jax's. Jax's carpet is still more pliable than the thicker rubber backing on the stock carpet, so installation of either should be relatively easy as long as it's laid out beforehand to relax the creases. Not having a rubberized backing on the samples, Car's products allow water to leak through very easily. Definitely get the rubber backing on this carpet or your jute backing will be getting wet and moldy before long if you use it as a daily driver I would suspect. Keep in mind that we are now talking about one carpet set which is considerably more expensive than the other if that's an issue for you.
Now customer service. When you are mail ordering stuff, especially across an international border, this is a critical consideration. Jax's sample arrived instantly after I contacted them...I think it was maybe three days up to Canada. I waited and waited for Car's samples to arrive. I got sick of waiting and ordered from Jax. Finally, with my carpet and floormats on the way from Jax and sitting at Customs according to the tracking info, the Car samples have finally arrived. Maybe I am too impatient, but I don't have months to complete these transactions. When I want something I want it now, and Jax will deliver in this aspect. Maybe Car's customer service is the norm, but regardless Jax's is just that much better.
In conclusion, I think the Car Motorsports carpet is a richer looking product than the Jax carpet with the above noted issues. The color match to stock is closer with Jax. The water permeability of the samples from Car needs clarification. And if you do a search there are previous posts regarding Car Motorsports' customer service. In the end I am still happy I went with Jax even after seeing Car's samples.
I hope that spiel helps the next person looking for carpet.
