Well I installed new 255lph fuel pump & new filter,removed stock cat w test pipe,car feels way stronger,but still detonates around 13lbs boost!?Is hotwiring the pump that important?Could it go from knocking to no knocks if the pump isnt/is hotwired?Now with the new blue tops in it,I would think my fuel system should be ok?Im using an adjustable reg set at 43lbs vac off.Car has new coil pack,wires & I went with Accel plugs[equivelnt to Autolites-23]Gee Im really hoping that Hotwire does the trick?Im only running a 93 chip w 94 octane gas.Should I add some fuel pressure-just in case the gauge is off?
