SignUp Now!Check your vacuum lines, you probably have a vac leak.
do u think i could b getting those readings possibly because of a bad turbo
i put brand new plugs in and keep getting carbon buildup car fires right up
car was running fine then i replaced the bottom end for a 4.1 291 .40 over stock crank rods 204/214 cam.the rest is stock .
got new plugs fired it up let it warm up and these r my numbers
o2 reads from 400-700 stay mostly under 650
af 07
l8 51
bat 13.9
int 112-122
bl 128
mph 00
clt 148
ats 76
r 750-850
tps.42
iac 84
cc goes all the way up to 250 then starts counting from 1 again
no error codes
i even bought a new iac valve
cant start with it disconected. i just start it and adjust it a 1/4 turn at a time and let idle settle then keep adjusting till i get 20ish then i reset tps sensor.when i try to reset i ground terminals a and b then i wait 30 sec disconnect the iac connector the car turns on but doesnt stay on with out me pushing the gas could this be a problem with the cam sensor being off or is that normal
