cas v4 fitment problem
MIKESGN
SENIOR MEMBER
i finaly got around to installing my cas v4 today
i bought it app year ago :eek:
its touching the rf side of the sway bar ?
the sway bar is stock and i had to remove the right side frame brace
(lower)
the left is fine but not the right side
i could make it fit if i trim down the spacers app 1/4 to 1/2 inch so it would be straight
anyone else came acroos this issue?
thanks
mike
Yes, I trimmed the shroud for the scoop which was all that was hitting, wasn't the intercooler itself on my car.
Sounds like you have the handle on the right fix. Just make sure nothing else is affected with the move such as oil filter access etc.
it ended up being worn out sway bar bushings
it was causing the right side sway bar to be further back and touching the intercooler
