I've had one of these on my car for 5 years and now it's gone nuts (I think it's my car, not the gauge.) I had to pull my pillar gauge pod down to put in the LEDs for Razor's alcohol kit. While I was in there, I rewired the gauge because it has always had an annoying problem.
It would work perfectly for weeks or even months, but then go nuts on a day when I needed it. I would start the car and the gauge would jump to a random light and stay there. It would not turn on the green "ready" light. I finally discovered that I could wiggle the gauge slightly and the ready light would come on (Or I could restart the car). I figured I had a wiring problem, but it wasn't frequent enough to worry with.
So, yesterday I completely rewired the sucker using the original instructions. I bought brand new, good quality 16 gauge wire, and I was very careful. I got the same connectors for the gauge end, ran the wires to the same locations, and even re-soldered the ECM connection. Apparently, that was too careful. Now it jumps to a random light and stays there every single time I start the car.
Wiggling it doesn't do anything now, so I took the retainer off the back where I could play with it. I can unplug the power, ground, or signal wire to the ECM for just a second, then plug it back up and it works perfectly. Any one of those wires will fix it, but I have to do this every time I start the car. I finally put the retainer back in and I'm reaching into the fuse box to pull and replace the spade going into one of the IGN slots. It works normally until I cut the car off again.
Anybody seen this or have some idea what to check? I'm going to call Casper's tomorrow, but I wanted to start here first.
