Caspers Ignition simulator, coil - module tester
jstahl
Boost, Nuttin like it!
Casper's CCCI ignition simulator for 86/87. Tests both coil and module. Works well, will test GM / Delco components and most aftermarket ignition modules that adhere to the Delco standard. Some off brands will not test, others will test if you tap the power clip to the battery terminal as to simulate rapidly applying / removing power. If the simulator fires the coil, it will continue to do so at that point. I discovered this while performing my own tests. Nothing wrong with the tester, just believe this tricks the aftermarket module since it's not 100% compliant with the standard.
$85 shipped.
Please put me first in line.
Is PayPal okay? If so please let me know the email address to send it to, either by replying or sending me a PM.
2nd in line if its still available. Thanks
