Cat ?
Brasco
Will the cats removed help or hurt with performance of my 87 gn? pretty much stock.
You will definitly improve performance by losing the cat. Probably give the car a little deeper exhaust note too.:biggrin:
The cats are the most restrictive thing known to man...except for the stock air cleaner box.:eek: :D
Carefully remove the cat converter and gently and lovingly place it in your nearest dumpster.:)
there is only one cat. on the car. removing it or gutting it will help performance.
Then purchase a "test tube":biggrin: to put in the location where the cat was.
