In a chip that I am working on, I put in Carl's cell 15 code patch and set it to trigger @ 50% TPS with a BLM value of 150. I bumped the FP to 47 to start. I noticed that in a DS recording of a run, my O2's sat around 839 during 1st gear(a little fat) and started to drop slightly at the upper rpms. 2nd gear was 830+ and did the same thing. In third and 4th they dropped from 780+ down to 750's. The highest amount of spark retard during the run was 3.8
Please correct me if I am wrong but I thought that the cell lock was to keep the value consistent ?, and by adjusting FP you could lower or raise the 02 #'s.
I made my chip a little fat on purpose and upped the FP, so I could slowly bring it down to get the 02's in the 780+/- range with little knock. I am worried that if I drop the FP I will lean out too much in the higher gears.
Setup is:
2850 lb car
Stock ported and polished turbo @19psi, blue tops, 62mm TB.
I don't know how to post the DS file here (Any ideas?) Let me know if you want to see it and I will E-mail it to you.
Paul
Setup is:
2850 lb car
Paul
