Hallo,
Finally Dorian is getting round to his 200-4R rebuild
The trans I have looks overall in good health except for the center support and the 4th clutch piston.
The 4th clutch piston is jammed in the center support and will not come out with reasonable coaxing.
I have a spare 200-4R around and the center support with 4th clutch piston move freely.
Can I swap one for the other?
The PN is the same. However the original center support has only one hole drilled through, whereas the replacement has to additional holes bored trough the middle (actually the three holes form a triangle around the main axis)
The original support has provisions for the two extra holes, but they are not drilled.
Will it work? Or should I try and pry out the old, slightly-warped, piston and swap the piston only?
THANKS
D
THANKS
D
