You will need to measure the installed height. The GN1's are supposed to be 1.75, but mine measured 1.725, which I heard earlier castings were. The K-motion 750's will work with the stock retainers, the Comp beehives require new retainers. The Comps have a 1.80 installed height, so at 1.75 or 1.725, you will raise seat pressure, and might run into coil bind issues. The k-motion have a 1.75 installed height, and should be good to .600. According to Weber, the Comps don't have enough open pressure. I would go with the k-motion.
